- Thank you received: 5
Cannot connect Data Access client (timeout).
One more thing, when I open Matrikon Explorer and connect to the OPC Server, then I am able to browse for OPC items with no errors.
I will ask the customer to send me the setup file for this OPC server.
I need a scenario/setup that I can reproduce in our office.
I don't think there are many items or branches... Quick OPC version 5.70.1152.1 is installed on the same computer and the sample .Net program also fails to browse...
Any idea how to proceed and solve this problem?
Thank you for your answer. I will check. By the way, Matrikon Explorer works fine with the same OPC server.
Is the server configured with large number of items or subbranches in the node the user is trying to browse into?
My customer is getting an error when trying to browse for OPC items.
+ The client method called (or event/callback invoked) was 'BrowseNodes'.
The OPC Server is Siemens.OPC.Server.DA.1
It is running on the same computer where our software is running.
The EasyOPC Client toolkit version is 5.63.232.1
Exceptions
System.TimeoutException: Cannot connect Data Access client (timeout).
ErrorId_{045406CD-8EEA-4F21-B3D6-DC9DB5A34E58}: RawEasyDAClient.HResult=0xC004C001
OpcLabs.EasyOpc.Implementation.ErrorEnhancement.Processed: True
OpcLabs.EasyOpc.Implementation.DAErrorEnhancement.Processed: True
HResult: -2146233083 (0x80131505)
Message:
Source:
TargetSite:
Message: Problem browsing OPC Data Access (OPC-DA) leaves.
Source:
TargetSite:
I appreciate your answer.
