Could not load file or assembly OpcLabs.EasyOpcForms
29 Jan 2022 16:01 #10571 by support
You could be right.
It could be better (not require the assembly in this case), so I will make a note, but I do not consider it a serious problem.
29 Jan 2022 15:47 #10570 by andis59
I installed www.nuget.org/packages/OpcLabs.QuickOpc.Forms/5.63.0-rev3 and the exception disappeared.
I don't get any popup form so the server certificate is probably trusted. Which is is suppose to be...
Maybe you have created the form even though you don't display it?
Thank you very much!
// Anders
29 Jan 2022 14:13 #10569 by support
What is happening here is that QuickOPC is trying to show the user a pop-up form for confirmation whether the (otherwise untrusted) server certificate should be accepted.
This is described here:
- opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...ited%20User%20Interaction.html
- opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...ows%20Forms%20Interaction.html
There are several options to resolve this, such as:
- You can assure that the server's certificate is trusted (which, in fact, probably cannot be guaranteed in full) - this is done by properly placing the server's certificate in the trusted peers store, or (insecure) allowing all certificates be accepted, or so,
- Disabling the "Windows Forms Interaction",
- Recommended: Add the www.nuget.org/packages/OpcLabs.QuickOpc.Forms/5.63.0-rev3 package to your project (even though it is WPF - it will work fine),
29 Jan 2022 10:56 #10568 by andis59
Sorry that I missed this!
The EasyUAClient is in a Class Library which is used from a WPF application.
29 Jan 2022 10:53 #10567 by support
What kind of project are you building/running? E.g. Console App, WPF app, Windows Forms App, Web app, Web service, etc.
29 Jan 2022 10:35 #10566 by andis59
I initialize the EasyUAClient object like this
_easyUAClient = new EasyUAClient { Isolated = true, IsolatedParameters = { SessionParameters = { KeepAliveInterval = 500, HoldPeriod = 60 * 1000 } } };
I get an exception
System.IO.FileNotFoundException
HResult=0x80070002
Message=Could not load file or assembly 'OpcLabs.EasyOpcForms, Version=5.62.456.1, Culture=neutral, PublicKeyToken=6faddca41dacb409' or one of its dependencies. The system cannot find the file specified.
Source=<Cannot evaluate the exception source>
<Cannot evaluate the exception stack trace>
I have used NuGet to get OpcLabs.QuickOpc.5.62.456, and in this package there isn't any EasyOpcForms.
I don't use the EasyOpcForms!!
Why do I get this exception and how to get rid of it??
