DeltaV browsing issue
23 Jan 2018 14:25 #5899 by support
Replied by support on topic DeltaV browsing issue
You wrote "still struggling" - have we communicated about this issue before? If so, can you please point to a topic on the forums, or email (date)? Thank you very much.
Some questions:
1. Does it happen only with browsing, or with other OPC operations too?
2. Does it happen always, often, sometimes, rarely?
3. What about other OPC clients - can they browse?
4. Does your client run in 32-bit or 64-bit process?
5. Is the client on the same machine as the server, or is it via DCOM - remotely?
23 Jan 2018 14:22 #5898 by support
Sent: Tuesday, January 23, 2018 10:54 AM
To: Z.
Subject: DeltaV browsing issue
Hi Z.,
We are still struggling with the Browsing issue using the DeltaV OPC server. Please see below the Inner Exception details.
Do you know what may cause this problem?
Exceptions Type: OpcLabs.BaseLib.Browsing.BrowseException Data: HelpLink: HResult: -2146233088 (0x80131500) InnerException: OpcLabs.EasyOpc.OperationModel.OpcException: An OPC operation failure with error code -2147221164 (0x80040154) occurred, originating from 'OpcLabs.EasyOpcRaw.DataAccess.RawEasyDAClient'. The inner exception contains details about the problem. ---> System.Runtime.InteropServices.COMException: Class not registered --- End of inner exception stack trace --- at OpcLabs.EasyOpcRaw.DataAccess.RawEasyDAClient.CheckOpcResult(CHResult* hResult) at OpcLabs.EasyOpcRaw.DataAccess.RawEasyDAClient.InternalBrowseNodes(ServerDescriptor serverDescriptor, DANodeDescriptor parentNodeDescriptor, DABrowseParameters browseParameters) at OpcLabs.EasyOpcRaw.DataAccess.RawEasyDAClient.BrowseNodes(ServerDescriptor serverDescriptor, DANodeDescriptor parentNodeDescriptor, DABrowseParameters browseParameters) at OpcLabs.EasyOpc.DataAccess.Internal.ForwardingEasyDAClient.BrowseNodes(ServerDescriptor serverDescriptor, DANodeDescriptor parentNodeDescriptor, DABrowseParameters browseParameters) at OpcLabs.EasyOpc.DataAccess.Internal.ForwardingEasyDAClient.BrowseNodes(ServerDescriptor serverDescriptor, DANodeDescriptor parentNodeDescriptor, DABrowseParameters browseParameters) at OpcLabs.EasyOpc.DataAccess.Internal.ForwardingEasyDAClient.BrowseNodes(ServerDescriptor serverDescriptor, DANodeDescriptor parentNodeDescriptor, DABrowseParameters browseParameters) at OpcLabs.EasyOpc.DataAccess.Internal.PSBoxingEasyDAClient.BrowseNodes(ServerDescriptor serverDescriptor, DANodeDescriptor parentNodeDescriptor, DABrowseParameters browseParameters) at OpcLabs.EasyOpc.DataAccess.Internal.EasyDAClientCompositor.BrowseNodes(ServerDescriptor serverDescriptor, DANodeDescriptor parentNodeDescriptor, DABrowseParameters browseParameters) at OpcLabs.EasyOpc.DataAccess.Internal.CompositeEasyDAClient.BrowseNodes(ServerDescriptor serverDescriptor, DANodeDescriptor parentNodeDescriptor, DABrowseParameters browseParameters) at OpcLabs.EasyOpc.DataAccess.Internal.ForwardingEasyDAClient.BrowseNodes(ServerDescriptor serverDescriptor, DANodeDescriptor parentNodeDescriptor, DABrowseParameters browseParameters) at OpcLabs.EasyOpc.DataAccess.Internal.LicensingEasyDAClient.BrowseNodes(ServerDescriptor serverDescriptor, DANodeDescriptor parentNodeDescriptor, DABrowseParameters browseParameters) at OpcLabs.EasyOpc.DataAccess.EasyDAClient.BrowseNodes(ServerDescriptor serverDescriptor, DANodeDescriptor parentNodeDescriptor, DABrowseParameters browseParameters) at OpcLabs.EasyOpc.DataAccess.Browsing.DANodeBrowseable.BrowseBranches(Object parentNode, Object nodeFilter, IEnumerable`1& branches, IEnumerable`1& exceptions) Data: ErrorCode: -2147221164 HelpLink: HResult: -2146233088 (0x80131500) InnerException: System.Runtime.InteropServices.COMException (0x80040154): Class not registered Data: ErrorCode: -2147221164 HelpLink: HResult: -2147221164 (0x80040154) InnerException: Message: Class not registered Source: OpcLabs.EasyOpcRaw.DataAccess.RawEasyDAClient StackTrace: TargetSite: Message: An OPC operation failure with error code -2147221164 (0x80040154) occurred, originating from 'OpcLabs.EasyOpcRaw.DataAccess.RawEasyDAClient'. The inner exception contains details about the problem. Source: App_Web_OpcLabs.EasyOpcClassicRaw.amd64 StackTrace: at OpcLabs.EasyOpcRaw.DataAccess.RawEasyDAClient.CheckOpcResult(CHResult* hResult) at OpcLabs.EasyOpcRaw.DataAccess.RawEasyDAClient.InternalBrowseNodes(ServerDescriptor serverDescriptor, DANodeDescriptor parentNodeDescriptor, DABrowseParameters browseParameters) at OpcLabs.EasyOpcRaw.DataAccess.RawEasyDAClient.BrowseNodes(ServerDescriptor serverDescriptor, DANodeDescriptor parentNodeDescriptor, DABrowseParameters browseParameters) at OpcLabs.EasyOpc.DataAccess.Internal.ForwardingEasyDAClient.BrowseNodes(ServerDescriptor serverDescriptor, DANodeDescriptor parentNodeDescriptor, DABrowseParameters browseParameters) at OpcLabs.EasyOpc.DataAccess.Internal.ForwardingEasyDAClient.BrowseNodes(ServerDescriptor serverDescriptor, DANodeDescriptor parentNodeDescriptor, DABrowseParameters browseParameters) at OpcLabs.EasyOpc.DataAccess.Internal.ForwardingEasyDAClient.BrowseNodes(ServerDescriptor serverDescriptor, DANodeDescriptor parentNodeDescriptor, DABrowseParameters browseParameters) at OpcLabs.EasyOpc.DataAccess.Internal.PSBoxingEasyDAClient.BrowseNodes(ServerDescriptor serverDescriptor, DANodeDescriptor parentNodeDescriptor, DABrowseParameters browseParameters) at OpcLabs.EasyOpc.DataAccess.Internal.EasyDAClientCompositor.BrowseNodes(ServerDescriptor serverDescriptor, DANodeDescriptor parentNodeDescriptor, DABrowseParameters browseParameters) at OpcLabs.EasyOpc.DataAccess.Internal.CompositeEasyDAClient.BrowseNodes(ServerDescriptor serverDescriptor, DANodeDescriptor parentNodeDescriptor, DABrowseParameters browseParameters) at OpcLabs.EasyOpc.DataAccess.Internal.ForwardingEasyDAClient.BrowseNodes(ServerDescriptor serverDescriptor, DANodeDescriptor parentNodeDescriptor, DABrowseParameters browseParameters) at OpcLabs.EasyOpc.DataAccess.Internal.LicensingEasyDAClient.BrowseNodes(ServerDescriptor serverDescriptor, DANodeDescriptor parentNodeDescriptor, DABrowseParameters browseParameters) at OpcLabs.EasyOpc.DataAccess.EasyDAClient.BrowseNodes(ServerDescriptor serverDescriptor, DANodeDescriptor parentNodeDescriptor, DABrowseParameters browseParameters) at OpcLabs.EasyOpc.DataAccess.Browsing.DANodeBrowseable.BrowseBranches(Object parentNode, Object nodeFilter, IEnumerable`1& branches, IEnumerable`1& exceptions) TargetSite: Void CheckOpcResult(CHResult*) DeclaringType: OpcLabs.EasyOpcRaw.DataAccess.RawEasyDAClient Module: App_Web_OpcLabs.EasyOpcClassicRaw.amd64.dll Assembly: App_Web_OpcLabs.EasyOpcClassicRaw.amd64, Version=5.41.1253.1, Culture=neutral, PublicKeyToken=6faddca41dacb409 CustomAttributes: FullyQualifiedName: C:\Program Files (x86)\Control-See\UCME-OPC\BIN\App_Web_OpcLabs.EasyOpcClassicRaw.amd64.dll MDStreamVersion: 131072 MetadataToken: 1 ModuleHandle: System.ModuleHandle MDStreamVersion: 131072 ModuleVersionId: 0c1165e8-dbca-41c8-b1c4-bf9845e2ed07 Name: App_Web_OpcLabs.EasyOpcClassicRaw.amd64.dll ScopeName: App_Web_OpcLabs.EasyOpcClassicRaw.amd64.dll Message: Problem browsing OPC Data Access (OPC-DA) branches. Source: StackTrace: TargetSite:
