Subscribing more items in Turbo Delphi 2006
07 Mar 2018 14:15 #6115 by oleg.rosa@seznam.cz
Isolated property solved my problem. :D
How simple...
Different sampling rates is good idea.
I use IPC (industrial computer) and MLC (motion logic control) from Bosch Rexroth.
Thank you very much for your help.
BR
Olin
07 Mar 2018 09:26 #6114 by support
On the OPC side of things, your ClientA, ClientB, ClientC, ClientD act as a single client.
Read:
Setting Isolated property to True should resolve it.
Another "work around" might be to force usage of separate subscriptions in a single UA session/EasyUAClient object by using slightly different subscription parameters - such as sampling rates of 997, 998, 999 and 1000 milliseconds, instead of just 1000 milliseconds for all the items.
Which OPC server are you connecting to please?
06 Mar 2018 20:21 #6113 by oleg.rosa@seznam.cz
I need subscribe to OPC UA Server ca. 3000 variables in cycle.
The Server allows max. 2000 items per one subscription.
When I use code in my program, see bellow, the Server returns only 2000 items on they change.
When I run my program twice (two instancies at the same time), the Server returns 2x2000 items (2000 in each program).
I need create two instancies of subscription for the server, but by another way than in the code below, probably.
Any idea?
procedure TForm1.SubscribeDataChange; begin ClientA := TEasyUAClient.Create(nil); ClientEventHandlers1 := TClientEventHandlers.Create; ClientA.OnDataChangeNotification := ClientEventHandlers1.OnDataChangeNotification; ClientB := TEasyUAClient.Create(nil); ClientEventHandlers2 := TClientEventHandlers.Create; ClientB.OnDataChangeNotification := ClientEventHandlers2.OnDataChangeNotification; ClientC := TEasyUAClient.Create(nil); ClientEventHandlers3 := TClientEventHandlers.Create; ClientC.OnDataChangeNotification := ClientEventHandlers3.OnDataChangeNotification; ClientD := TEasyUAClient.Create(nil); ClientEventHandlers4 := TClientEventHandlers.Create; ClientD.OnDataChangeNotification := ClientEventHandlers4.OnDataChangeNotification; Try while (.....) do begin if (iRowNr1 <= 1000) then begin ClientA.SubscribeDataChange(...); end else if (iRowNr1 <= 2000) then begin ClientB.SubscribeDataChange(...); end else if (iRowNr1 <= 3000) then begin ClientC.SubscribeDataChange(...); end else if (iRowNr1 <= 4000) then begin ClientD.SubscribeDataChange(...); end; iRowNr1:= iRowNr1 + 1; end; Except End; end;
BR
Olin
