Module win32com Not Found - Need location
14 Sep 2018 19:50 - 15 Sep 2018 06:22 #6651 by support
I think you need either this:
pypi.org/project/pywin32/
or rather this:
pypi.org/project/pypiwin32/219/
Instructions: In C:\PythonXX\Scripts, do:
pip install pypiwin32
Last edit: 15 Sep 2018 06:22 by support.
14 Sep 2018 14:56 #6647 by steve.korber
Using the example Read.Main.py and I am trying to read a tag from our Ignition OPC UA Server. The python file cannot find the library win32com.py so I can't run the file. I have left the file in the default location "C:\Program Files (x86)\OPC Labs QuickOPC 2018.2\ExamplesCom\Python\CPython\Console\UADocExamples\_EasyUAClient" but it still doesn't work. Where is this file located?
14 Sep 2018 14:46 #6646 by steve.korber
I'm trying out a trail version and I just want to make sure I can read a OPC-UA tag from out Ignition Server. I am using the Read.Main.py provided and I made some changes to the endpoint but the module win32com is not found on my machine. Where can I locate this library file? I just want to run this in IDLE (default python environment).
ModuleNotFoundError: No module named 'win32com'
Time to create page: 0.159 seconds
 Recommend this on Google
